Discuss Redundant iron gas pipes in the Plumbing Jobs | The Job-board area at PlumbersForums.net
R
Reltub
What's people's view on the need to cap redundant gas pipes. E.g. Next to gas meters.
I know in the regs it says that they should be capped with an appropriate fitting.
Is it really necessary?
Would filling it with fjc or similar suffice?
Would gas safe pull you up on it if it wasn't done?
Just thought I'd throw this out there as i was interested.
If its an old service pipe it has to be capped as a gas leak can track up the old pipe.
I've had this happen to me and they had to dig the pavement and the road to fix the leak
IMO they should be vented to outside air
I don't mean service pipes from the street, I mean old iron where they've put a new copper gas run in.
Regards
Dob of silicone in the end for me
As you have stated the regulations 6(3) require that " any person who disconnects a gas fitting shall, with the appropriate
fitting, seal off every outlet of every pipe to which it was connected."
So yes, it is necessary.
Where do you stand if you are not the one who disconnected it?
Last one working on it responsible of course. So even if you are working on other parts the installation then
it is your look out.
Reply to Redundant iron gas pipes in the Plumbing Jobs | The Job-board area at PlumbersForums.net
All, Belfast, Northern Ireland. I am in a bit of a predicament. I have recently had a stove fitted in a chimney that had a disconnected and...
Hi, I am a homeowner but caught between a rock & a hard place. I am trying to get a Vaillant ecoTEC 630 plus serviced but the gas safe engineer &...
2K
This issue arose about a year ago. Does anyone have an idea why I occasionally hear (about once every hour or longer) a hammer related noise...
Hi there, Big gas noob here. We got a gas cooker installed a few days ago, and the gas cooker is now sitting quite far away from the wall (3cm...
I'll pop this into the general advice forum as it seems the most active, but mods - feel free to move if there's somewhere more appropriate. Thank...
2K
