Discuss Recessed Shower Valve No Flow in the USA area at PlumbersForums.net
I've just fitted the recessed dual shower valve photographed. Flow was fine until I went to calibrate the temperature this morning, so twisted the bottom cartridge and adjusted the flow on the isolator valves. now there is no flow out of the head at all (isolation valves fully open) having put everything back as it was and I can't work out why. Any advice why would be much appreciated.
Chris
Need to leave the iso valve fully open and move the cartridge back to where it was not for regulating just move the temp nob over a notch/spline to adjust
Crap in the pipes? Air lock? Have you got a low pressure system or a combi boiler?
I have found a few of these recessed shower valves have very small waterways on the mixing valve and can be blocked by little bits of grit like hard limescale. Only happened on low pressure systems. Stuck a foot pump in the hole and blew it a few times live. Got very wet but cleared blockage
Reply to Recessed Shower Valve No Flow in the USA area at PlumbersForums.net
W
Hello all. I have fitted three new Saracen timed flow valves to existing shower rooms. But these valves are still allowing water to flow from...
Hi all I had a new bathroom fitted about 4 months ago and all was fine until about a week ago. But now when I turn the lever to run the rain head...
Hello, I have quite low flow rate for my electric shower (a piddling 5L/min), and would like some tips or advice about how to solve or find the...
Essaboy
E
J
I have an Arteform shower valve in my bathroom - top lever for the main shower head, middle for the handheld hose and bottom is the thermostatic...
Hi All I had an unvented cylinder fitted about 6 years ago. It only supplies hot water to my shower. I was hoping for a much better flow rate from...
Steveo111
