Discuss Radiator Valve Caps Replacements in the Central Heating Forum area at UKPlumbersForums.co.uk.
Tags:
  1. JayKay70
    JayKay70 Member
    Hi all,
    I am looking for a place to buy Radiator Valve Caps.
    Picture 1: Got 1 radiators with no caps
    Picture 2: Got 4 radiators with this cap
    Picture 3: Got 3 radiators with this cap
    Picture 4: No cap but the pin is different size compared to picture 1
    Picture 1, each pin is 15mm high and 6mm thick at the top
    Picture 4, pin is 10mm high and 6mm thick at the top
    On each radiator i also have a Drayton TRV4
    I am just looking to replace each one so there is some uniformity, right now it's all over the place:eek:
    Preferably chrome ones if possible, if not than white ones.
    Any ideas?
    All the best
    Jay
  2. Riley
    Independent plumbers merchant should be able to sort you out
    • Informative Informative x 1
  3. JayKay70
    JayKay70 Member
    Thanks Riley, i have found a online website that sells them in packs of 10, due to me not being able to drive it's cheaper for me to buy online.
    Jay
  4. Rob Foster
    Rob Foster Top Contributor!!
    It’s very important to make sure rad valve caps are fitted, little people can fall small heads fit into corner between wall and rad. Brass head then penetrates child forehead ouch ! My surveyed friend fails rentals for letting if rad caps are missing for this reason. Rob Foster centralheatking
    • Agree Agree x 2
  5. Best
    Best Trusted Plumber Top Contributor!!
    First 3 photos are of Peglers Terrier older type valves.
    I actually have some spare used heads for them, lockshield and wheel head.
    The forth valve is one of the standard cheap valves
    You can also get sets of universal heads that might sort it.
Loading...
Similar Threads - Radiator Valve Caps Forum Date
Help with radiator valve New Member Introductions Feb 1, 2019
8mm microbore, twin entry radiator valves and ancient radiators Central Heating Forum Jan 29, 2019
  1. chrome radiator valve cap
