Discuss putting a second prv in line in the Plumbing Jobs | The Job-board area at PlumbersForums.net
B
Billy Bob Bob
it was suggested i do this rather than remove the boiler from the wall,,being the sort that does things correctly i have issues with doing this,surely if you put a prv in line with the old one effectively having 2 3 bar prv,s you are asking for trouble in the event of a problem,anyone else agree? prv1.jpgprv3.jpgprv2.jpg
Wouldn't be happy doing that either Mark.
I'd rather reroute the existing prv discharge into the return pipework and fit a new prv also on the return.
Apart from the increase risk of leaking I don't see the problem.
converting an old OV system to a sealed one the PRV goes ware you put it on the system or with the Robokit.
what if the first/old prv is jammed shut being as its knackered anyhow I would bin it for a new one, not for the next 2 weeks though :) I am presuming you mean you put the replacement on the drain off line behind the original one.
yes but we are talking a combi here,for one thing you are technically altering a safety device,thats where i see a problem
thats what i am thinking,how many old ones have we seen that dont go off at 3 bar because they are shot
however I have sometimes had to run a prv from some other part of the system and run the original one straight back into the ruturn as per croppies post, all done with manufacturers blessing. Just label the original prv to show where the other one is.
I agree with you, its not something I would do. However in theory is there actually anything wrong with it? The fact you normally replace a prv is because it is passing, obviously if you are there because its not opening at all then there is an issue. Then the first prv will open at 3 bar and the second shortly after as there wont be much pipework in between. The argument that one might fail to open is redundant as a brand new one is probably just as likely to have that same issue.
Reply to putting a second prv in line in the Plumbing Jobs | The Job-board area at PlumbersForums.net
