Discuss Primary Ventilated Stack Replacement - DIY or Professional? in the USA area at PlumbersForums.net
Hello.
We woke up in a VERY smelly house this morning. We'd been getting the odd pungent whiff here and there ever since we'd taken the dining room ceiling down to assess the condition of/replace some joists. ( - the internal waste stack runs through the dining room).
After checking that the noxious odour wasn't the result of my Wife's morning oblutions, I checked the waste connections on all the sanitory appliances and found no issues. I checked that all the traps were still sealed, and they were. After that, I started to look at the stack and noticed that it is of the Marley push fit variety, and now being almost 50 years old, it looks like some of the joins in the the stack are leaking with evidence of seepage.
All of the waste pipes look to be connected by push fit too.
I'm contemplating DIY replacement - at the moment it is not an issue to bash out the plaster covering the stack (precautions taken for asbestos) and with the right access equipment, get onto the roof and remove/replace the stack top vent. Our home is a typical 70s built 2-story suburban dwelling.
My only concern is that the bottom piece of the stack with it's long radius bend is embedded in conrete turning a relatively straight forward job into a complicated one, if I were to attempt it myself. There is a push fit connection at ground level. I'm figuring if I use PVC pipe with solvent welded joints to replace all of the stack above ground, I could leave existing bottom piece in situ, perhaps replacing the O ring?
Am I clinically insane for even considering this? I would of course consult Part G of the building regulations before starting any work.
Thanks in advance for your help.
PP
Depends on your skill level it’s doable but if you haven’t done it before it will take time
If you have the tools and are handy at diy then crack on but be warned its not as easy as it looks especially if you are going to solvent weld pipework , personally I would replace with push fit on the main stack good luck. Kop
Reply to Primary Ventilated Stack Replacement - DIY or Professional? in the USA area at PlumbersForums.net
Sonya K
Hi all, I'm installing a concrete patio out back. By the wall under the kitchen sink I have an existing P-Trap gully for the grey water from the...
