- Messages
- 289
Customer's sealed heating system is losing pressure from about 1 bar to zero overnight. Pressure rises to 2 bar when heating is on.
No water was discharged from the PRV and no other major leaks.
Expansion vessel is still at 1 bar (same as 2 weeks ago).
The pressure rises very quickly when topping up and also drops very quickly when releasing from PRV. Also tried releasing water from a drain valve downstairs and again the pressure dropped quickly.
I have noticed an AAV hidden away is leaking very slightly and wondered if that could be causing the drop in pressure, but thought it wouldn't drop that quickly.
In draining off less than half a litre of water, the pressure dropped from 1 bar to zero, in an 18 rad system?
Does this sound right?
