Discuss powerflush association water samples in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Deleted member 84970
I sent off a water sample to get tested but not heard anything from them even after emailing a few times.
Can anyone recommend anywhere else that can test water sample from central heating ?
Most chemical manufacturers do them fernox do
Adey have a testing service . Kop
Reply to powerflush association water samples in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi Folks, I have a challenge with a Main Eco Elite 30 Combi which is short cycling on the CH. Water works fine. As soon as you have call for heat, the boiler fires up, modulates, but jumps very quickly (about 30 seconds or so from 40'ish all the way to 70, burner disengages putting it the...
So a strange conundrum regarding water temp if anyone can help resolve, would be much appreciated. Ive tried to give as much info as possible to give a full picture but let me know if ive missed anything. I have a Baxi Avanta 25h heat only boiler. Works fine. Unvented 300ltr megaflow. Stated...
During an install of new boiler ('old' boiler died after 11-12 years) the system was "drained" but I guess maybe 90% of water was left in the (rather large) underfloor pipe system. What is the best way to tell how much inhibitor should be added in this case? (also taking account that system was...
J
Turned the system from hot water only, to hot water and central heating the other day. After it working briefly, it has now stopped all together. The display isnt showing a fault or anything - it is just blank. After reading the service guide that came with it - I am confident there is power...
James Middleton
J
Background 24 apartments are equipped with thermal stores of (100 to 150 litres) with immersion heater capability. Individual demand of each apartment for domestic hot water varies greatly in timing and volume. Thus the oil boiler is required to work for long periods which is uneconomical...
