Discuss Potterton HE18 BOILER in the Plumbing Jobs | The Job-board area at PlumbersForums.net
H
hilly10
Hi Guys
I have problem with my boiler it was running normally until Thursday night when I noticed the rads were hot even though the thermostat was on low. The boiler carried on till the pressure went in to the red it then cut out. The boiler will run normally with just the water on but as soon as you switch the heating on it will cut out when the pressure climbs into the red. There are two Temperature sensors (flashing neon amber lights) only the end one flashes. Is the fault a faulty thermostat
No. It's not. It's not a diy repair.
We cannot and will not give advice on the installation or repair of boilers, cookers or ANY gas appliances for your own safety.
Please go to Gas Safe Register | Ensure your gas engineer is registered. or post a thread in the 'I'm looking for a plumber / gas engineer' section of these forums remembering to include your location. [DLMURL="http://www.ukplumbersforums.co.uk/im-looking-plumber-gas-engineer/"]I'm looking for a Plumber or Gas Engineer[/DLMURL]
If you are gsr please increase your post count to 10+ then send a PM (Private Message) with your gsr details to either Gas man - View Profile: gas man - Plumbing Forum | Plumbing Advice | Plumbers Forums | A forum for plumbers advice in the UK or Redsaw - View Profile: REDSAW - Plumbing Forum | Plumbing Advice | Plumbers Forums | A forum for plumbers advice in the UK who will check you and then give you access to the gsr private forum.
Providing gas-related advice to anybody who should not be touching gas and cannot prove their competence is unacceptable. We will take whatever action we deem appropriate to prevent such advice being given
Thank you.
UKPF TA's, Mods and Admin teams.
[DLMURL="http://www.co-gassafety.co.uk/deaths.html"]CO Gas Safety[/DLMURL]
http://www.ukplumbersforums.co.uk/central-heating-forum/42241-notice-gas-safety-related-advice.html
Reply to Potterton HE18 BOILER in the Plumbing Jobs | The Job-board area at PlumbersForums.net
