Discuss Pneumatic flush valve failing in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, I've got a problem with a Gerberit pneumatic dual flush valve.
It has two buttons on the actuator plate, when pressed individually they do nothing, you now need to press them both at the same time in order to get it to flush. The toilet was installed around 5 years ago with no problems until now.
Any idea what this could be and how to fix?
Do you know the model? Is it a bellows type set up? If you can remove the faceplate can you blow down the pipes individually and achieve a flush
Reply to Pneumatic flush valve failing in the Plumbing Jobs | The Job-board area at PlumbersForums.net
