Discuss Plumbers and electrics! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
R
Reltub
Getting confused and conflicting advice regarding what we can and can't do regarding electrics without the qualifications so wondered if you guys could help as i know you are all very usefull! I was under the impression we was allowed to connect to existing spurs etc as long as we aren't altering the ciruit, so wiring a combi in airing cupboard and using immersion spur is allowed? straight swap shower is allowed? then someone tells me you have to be part p, then someone says its changed again and you can! found this website: Part P Full Scope, Part P Defined Scope, Part P Full Scope Training Courses, Part P training (full scope)
it says minor works not notifiable (like the works ive mentioned) but does that mean you are allowed to do them or shall i book on the course lol.
Cheers
Glad we don't have that balls up here, we do work for an English company who said we'd have to be part P to wire a shower when we changed it for another electric one...
Its crazy and too confusing i just want clear guidance lol so i can make sure im doing everything by the book!
This document couldn't make it clearer. Bear in mind that the special location in a bathroom only extends up to 2.25m so in most cases you can actually install bathroom lighting (i.e. spotlights etc) without notifying the work.
So replacing an electric shower would be notifiable work as it's an addition/alteration (only exception being if it's an exact swap, i.e. Mira Jump 8.5KW for Mira Jump 8.5KW).
Adding a new radial circuit for a shower pump would be notifiable work but fitting a fused spur off an existing ring mains to power the pump would not be.
Fitting spotlights in a bathroom ceiling over 2.25m high would not be notifiable work (outside of special location) but fitting IP rated wall lights around a bath would be.
Fitting a new cooker to an existing isolator would not be notifiable work but installing a new cooker circuit would be.
Even non-notifiable work is meant to be inspected and tested to prove it is safe though and it would be tricky to do this properly without the relevant experience and a test meter!
In reality now so little work is notifiable I think that the competent person schemes are going to lose a fair chunk of business. I am looking into contacting my local building control officers now and asking how much they would charge me to direct notify given that I have my inspection and testing certificates. Apparently the charges have to be reasonable and proportionate to the amount of work they have to do to test contractor's work.
[DLMURL]http://www.niceic.com/Uploads/File8952.pdf[/DLMURL]
Electrics are very simple really, if your swapping stuff doh worry about it. If your altering stuff then know what yam dewin.
A simple understanding if ohms law, basic circuits and protection and you can do most things. Cable sizing knowledge can be needed but most domestic sparks cable size once every 13 years. A bit like one a day heating engineers with gas pipe sizing lol.
Reply to Plumbers and electrics! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, I'm installing a concrete patio out back. By the wall under the kitchen sink I have an existing P-Trap gully for the grey water from the sink, dishwasher, washing machine etc. When I pour the concrete there won't be any chance to dig it up anymore. From my own research I get the...
