Discuss Please help with removing screw from bathroom tap in the USA Plumbers Advice area at PlumbersForums.net
I am trying to replace the flow cartridge in the bathroom tap. I have turned off the water and removed the tap cover but cannot get the screw to turn. The screw looks to be some variation on a philips screw, i have tried different screw drivers but to no avail I have attached a picture, any advise would be greatly appreciated.
Looks like a pozi drive and probably a no.2 although hard to guage the size from the photo. You should be able to get a selection of pozi bits fairly cheap from somewhere like screwfix. You won't be able to get a decent purchase on it with a philips bit.
Taps are often held on with Philips rather than Pozi, and using a Pozi will chew it. A bit strange but true. Have you got some real Philips bits or screwdriver of right size? (Soak it with WD40 as above first).
Cheers,
Roy
Reply to Please help with removing screw from bathroom tap in the USA Plumbers Advice area at PlumbersForums.net
