Discuss piping to condensate trap to avoid freezing in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have just had a new combi boiler fitted by an approved and Which recommended installer but I noticed that the condensate trap/soakaway was only 70 mm (should be 500 mm) from the house wall. It was not practical to link to grids which were a full house length away (poor boiler siting in my porch replacing old trad boiler) and pipe from washing machine slopes slightly uphill!
They have agreed to put this right but they are talking about taking the pipe to the right (so we are away from the side gate and then dropping vertically to the ground where they plan to run the required 500mm horizontally to the condensate trap either just below ground level (the whole area is concreted over) or possibly a little deeper to avoid a trip hazard. They will lag the exposed pipe.
I am a bit concerned the horizontal run just below ground will be prone to freeze. Also is it not good practice to keep joints above the ground where you can see if a leak develops (I understand the condensate is slightly acidic so you would want to know about leaks near the house).
The only alternative I can think of is dropping the pipe at the required angle such that it arrives at the condensate trap 500 mm out from the wall though obviously it would protrude but more visible as higher up.
I am not in any way a plumber and trying to figure this out is causing me a lot of stress. Please does anyone have any useful advice or suggestions?
Thanks in advance
Thanks for replying. Sorry yes it is meant to be a soakaway. Currently it is just a 110 mm plastic container filled with limestone chipping sitting in concrete 70 mm from house. The installation instructions say it should have 100 mm of chippings around it (so total diameter of 300 mm) and be 500 mm away.
I don't have any great objection to the soakaway if it is done properly and it works? I would guess the installer is trying to avoid installing a pump because of the extra work/expense and a lot of pipework would be needed incl getting past a side door.
Firstly, is this a traditional heating system with rads where you have simply replaced the boiler? The reason I ask is because if it is it produces condensate at a different rate from a system designed for lower flow temps.
If it is, then Town's suggestion of a condensate pump is spot on. It stores it till it reaches a level then pumps it all away. By pumping lots away at the same time it has more thermal mass so it's less inclined to freeze.
Insulating only WILL NOT stop it freezing otherwise.
The only way to ensure it does not freeze is to fit trace heating under the thinnner insulation so you can replace the heat energy the condensate loses as it travels on its way.
So, three choices for you:
1 - internal (almost zero risk)
2 - condensate pump (very slight risk)
3 - trace heating (done properly zero risk)
HTH
Thank you so much for responding. I did have a traditional boiler which failed. This has been replaced with a Worcester Bosch 30i ERP feeding 6 radiators. Are you suggesting I can go with their horizontal pipe just below the ground suggestion if they add in a pump or trace heating? Should I be concerned about possible leakage in the future on a bend near the house? Thanks again
I use the soakaways , nothing wrong with them but yes it should be further away than 70 mm. Further away the better IMO .
They are the last resort really.
Thank you to everyone who responded. It appears that this was a conversation that should have been had before the boiler was sited. I did not know about the need for condensate discharge but I assume he did. Thanks again
I have used these but some boiler manus do there own https://www.NoLinkingToThis/p/grund...8Jd-5aM392gpdv38RHsaArDDEALw_wcB&gclsrc=aw.ds
Reply to piping to condensate trap to avoid freezing in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Just started gound work on self build bungalow and wondering best way to do below ground soil pipes. For toilet I was going to go straight down through slab and out through deadwork into a manhole. I will work out falls from manhole and set the height of the waste water system as required. For...
Hi all, this is probably a daft question but I need to run my cold feed from one side of my wall mounted boiler to the other. Running it beneath the boiler is difficult with lots of obstacles, is it okay if I run soldered copper over / across the top of the boiler? It'll be about 4" off the top...
