Discuss Pipe sizing charts beyond 30m please in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
Masood
Afternoon all,
Please can someone help me out by posting a screen grab or link to pipe sizing charts for copper and barrel beyond the standard 30m of 28mm given in the Viper manual. Or the equation for calculating pressure drop given heat input / flow rate required. I need the data for 35mm copper and 1" or 1 1/4" barrel.
I have the method for calculating TIV so will know if I'm heading beyond Domestic limits. If I find myself going over I'll get a Commercial engineer in to help. Just need pipe sizes right now to price up the job. Both are domestic jobs but long gas runs from meter to appliances.
I'm on hols at the mo and have no access to reference books, only the Viper manual and need to do a couple of quotes, hence the request.
If it helps, I need the following:
1)
24KW / 2.5m3/h
32m effective length, initial 22m (effective) must be barrel.
2)
34KW / 3.53m3/h
38.7m effective length, initial 6m must be barrel
Thanks in advance,
Masood
Hi masood do u use an android phone if so download Mr combi app - gas pipe sizing. It goes up to any length required.
I don't have any experience with barrel and not sure if barrel is one of the choices in the app but it will certainly give u minimum sizes needed.
Cheers Kris will try and download it. Internet pretty flaky here though so might not work...
I've just used mr combi app
2.5 cu/m/hr 32 metres. Pressure drop with 25 mm steel is 0.8mb
same figures with 32mm steel 0.32mb
3.53 cu/m/hr 38.7 metres Is 32mm At pressure drop of 0.387mb
wont give me the next size pipe so presume that it goes into comm.
is this any good, but do check figures out again.
stani
stani
Many thanks Stani. I've done the quotes based on the above. Tried checking the figures against the equation in Tolley's but the numbers don't work out. That may just be me rearranging the equation wrong, though! Will have a proper go when back in front of my computer with a scientific calculator to hand...
Reply to Pipe sizing charts beyond 30m please in the Plumbing Jobs | The Job-board area at PlumbersForums.net
