Discuss Pipe diameter from tank for thermostatic shower? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I
imsparticus
What pipe diameter would you recommend to feed an unpumped thermostatic shower from a vented hot water cylinder via a new Essex flange? The run is approx 22 meters (up into the loft along and back down), the cylinder is fed via a 28mm cold inlet pipe and the cold water tanks are roughly above (2meter head) where I want to install the shower.
I was thinking of using 28mm but would it take longer to get the hot water that far compared to say 22mm?
All recommendations gratefully received.
Just for info we have another shower but much closer to the hot water cylinder that has good pressure so I'd be happy if i can match that.
Thanks in advance.
22mm should be fine i reckon
not a lot of head on that though
Try to use bends rather than elbow joints where possible
Consider using a pump though for a real decent shower
its the head above the highest part of the pipework you need to look at
Thanks, can't do much about the height as I have 2 huge linked cold water tanks in the loft and the top of them are close to touching the rafters so can't go any higher.
I was worried that the run was so long that it would take an age to get hot water to the shower and be worse the larger diameter pipe I used. I'm trying to use a method that just in case the pressure isn't enough I can always opt to add a pump later.
Reply to Pipe diameter from tank for thermostatic shower? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
We have a gravity fed hot water system in our the house we have just recently moved into. It works fine with the downstairs shower, however we are...
Hi, I'm in my new build 2 years and the shower pump has died. I have an air to water unit downstairs is in the utility which I've been told is...
Hello, and thanks for taking the time to read. I'm trying to work out if the idea I have is practical? The water pressure in my newly renovated...
Hi I recently did some pipe insulating in my loft. The only two I didn't do were the vent pipes. Not sure if that is the right term for them...
A
Hey, here goes and I hope it works.. never used one of these before! I have a Sagittarius Ergo mixer shower min bar of pressure required 1 bar...
