Discuss Pilot light and open windows in the Plumbing Jobs | The Job-board area at PlumbersForums.net
H
Help4me
We have a gas back boiler with fire on the front. Now the weather is better we have the windows open for most of the day. There are two large windows both on the opposite wall to the fireplace. We keep the pilot light on all the time as we heat the water up with the gas as we've been told this will be cheaper than electricity.
Will the pilot light be ok with the draft coming in from the windows? Or, should we turn it off and only put it on when we want to heat the water up? Also, while we are heating the water should we close the windows?
Thanx
open flued appliances require permanent ventilation this is required to ensure the appliance has enough oxygen to burn safely this is calculated by the maximun input rating of the appliance(net) ie boiler and fire combined giving a total kw rating you then take of 7kw for adventitious ventilation and the remaining kw's are calculated at 5cm'2 per kw an example would be you have a boiler with a maximum net imput rating off 20kw and a fire of 7kw max net input rating the calculation would be 20+7=27kw-7kw x 5cm'2=100cm'2 purpose provided ventilation required for further guidlines look at bs 5440 part 1 and 2
The pilot has a safety cut off, will isolate the gas supply if it ever goes out.
Thanx
This appliance is known as a standing or permanent pilot appliance. The pilot light is designed to be constantly on. Tuning off and on at your leisure may cause issues. Although, the odd occasional downdraft etc may extinguish the pilot there is a safety device in place to shut the gas off. Opening windows should have little or no bearing on the pilot.
Lol! Yeah, fraid it was like rocket science to me. Thanx to everyone though. It's put my mind at rest.
practicing for our acs assesments are we?.
LOL, or hes got a Gas safe inspection soon!!,
Help4me, have you had your boiler service recently and have you got open ventilation through the wall??
Reply to Pilot light and open windows in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Have a sytem boiler with unvented cylinder with 2 heating zones plus hot water in a house we moved into recently. To start with we were always...
We live in a 1980s four-bedroom detached house. The time has come for new central heating. The current system is a mild revision of the original...
2K
    • Informative
Why am I not surprised? Britain’s gas network still using engines from 1960s RAF fighter jets Ageing aircraft turbines will cost millions to...
Some advice please about a really worrying problem. I live in a terraced 2 bed room house. 10 days ago the gas combi boiler stopped heating the...
Boiler and Megalow mistery Hi, Just moved into a house from a flat and I have a couple of queries. We have a Worcester gas fired boiler -...
1K
