Discuss performa 24 no hot water already changed diaphram in the Plumbing Jobs | The Job-board area at PlumbersForums.net
B
brokite
hello i have a performa 24 gc 47-393-06 an old one.3 months ago the hws was cold and the diverter valve pin was not operating the micro switch so i changed the diaphram and every thing was fine for the last 3 months then last night ran a bath with hot water was fine then after went down stairs to wash up no hot water i got home today and checked diaphram and also checked mcw filter and also the pin moves freely in and out of both brass bushes flow seems ok and i also checked the flow ventura which seems ok any advice with this would be appreciated thanx in advance
Please read the forum rules.
For very obvious reasons, no advice related to gas appliances can or will be given to a non gas safe registered engineer.
only touching the water side of things didnt realize you had to be gas safe to adjust/repair the dhw/mcw side of things appoligies
Reply to performa 24 no hot water already changed diaphram in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Afternoon. I have an issue with no water flow from any of the hot taps in the house, I can't seem to find a solution to the issue. System is a...
M
Hello, We’ve recently moved into a fairly old, fairly big detached house (i.e. fairly draughty, but not too bad by any means) with a fairly new...
MartinPod81
M
Hi everyone, Could someone please explain if this set up is normal and what changed: Stopcock under kitchen sink turns off cold water supply in...
Can anyone help me with an ongoing issue I've had since I had an annual service on my combi boiler, which is a Potterton Performa 24. Literally...
