Discuss Oil Boiler not heating hot water after draining system. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
After emptying the water from the lowest drain valve in the house (Bottom of downstairs radiator) and refilling the system. The radiators warm up fine but the hot water tank doesnt. I have turned on the imersion heater and the hot water created runs out the taps fine but the boiler (Kerosene) will not heat the hot water for the taps, only the radiators.
Any suggestions would be greatly appreciated.
Reply to Oil Boiler not heating hot water after draining system. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
K
We have a dual heating system, a solid fuel stove with back boiler and a external kerosene heater. The kerosene heater is working fine heating the radiators and the water for the taps The solid fuel stove will heat the water for the taps but the radiators will only get luke warm. Can anyone...
Hi. I hope some one can help. I have a condensing oil burner and it runs fine but the radiators don't heat. Heats the hot water fine. The pump runs and the thermostat turns the boiler on and off. Thinking it could be a thermistor. All help greatly appreciated.
T
Hi We urgently need to get our h/w cylinder replaced because it's leaking. Our current system is oil boiler feeding underfloor downstairs, radiators upstairs and an unvented hot water cylinder for hot water. We are thinking of moving to a heat pump at some point but aren't ready to do this. My...
Firstly I won't be touching or going anything... I only want advice if this is right.. my partners dad has a aga that is solid fuel unregulated heat source and a oil boiler. The problem the hit water cylinder doesn't have a stat thus why the hot water is roasting hot but there is a pipe stat on...
I recently installed new hot and cold feeds to a new downstairs cloakroom. After refilling the system the hot taps were all dribbling, spluttering and showing signs of an air lock. I attached cold mains to a hot tap and left it running for 15 minutes, while opening up each hot tap. They all...
