Discuss Non Return Valve on low pressure system in the Plumbing Jobs | The Job-board area at PlumbersForums.net
GGg
Previously wrote on here as the tank in the attic was overflowing due to mains pressure back flow up the hot water tank fed pipes.
Resolved this issue with a NRV on the hot pipe coming from my twin pump. (See pic)
Solved my issue but because the NRV is spring loaded the pump doesn’t turn on when I open the hot tap because the pressure isn’t enough to trigger. Either have to turn cold on the bath which activates the pump and then turn on the hot or run the hot downstairs in the kitchen which activates the pump as enough pressure.
What are my options?
Thanks.
Thanks.
Pipe it up correctly.
Negative head pump or pipe it up properly with balanced feeds
Thanks. Found a non return valve with a flap rather than spring loaded for low pressure systems. Will try that.
Needs to be horizontal not vertically installed then
Ideal scenario I would just bring new cold feed down the the shower mixer from the tank but brand new en-suite and new carpet laid on landing doesn’t make this feasible.
Ask the carpet fitters to come back and lift it normally around 40-50 to lift and relay a day later etc so no excuse
And then rip the tiles up in the bathroom, RIP off all the wall panels remove the shower cubicle and tray. Thanks anyway.
Well you didn’t say that but depends where you’ve teed off for the shower wall boards shouldn’t need to come off
What pump have you installed? It's a twin so obviously feeds hot and cold supplies so I'm confused as to where/how your getting mains backflow up the hot pipe?
Thanks.
Can you put up a system diagram so we can all have a helpfull look
centralheatking
Reply to Non Return Valve on low pressure system in the Plumbing Jobs | The Job-board area at PlumbersForums.net
