Discuss Noisy Condense Pump in the Plumbing Jobs | The Job-board area at PlumbersForums.net
G
geron
I have just had a Worcester FS30CDi fitted which seems to be fine except for a fairly loud buzzing/vibration noise shortly after starting up. I guess this is from the condense pump, it lasts for about a minute at a time and is very noticeable because the boiler is otherwise pretty silent. Is this normal, I have not had a condensing boiler before?
it doesnt have a internal condense pump
condense pump are additional and used if not able to run to waste..so unless you have an additional condense pump fitted the noise is something else
external Condense pumps are Pretty noisy.
They are used as newbie says when the boilers condense can't be run due to position of appliance in relation to nearest external wall or waste pipe.
The FS range have a condense pump as standard as they are floor mounted, so from what you say I guess that is the noise and it is pretty normal.
Reply to Noisy Condense Pump in the Plumbing Jobs | The Job-board area at PlumbersForums.net
T
Hello, I have just moved in to a new flat this week and have a problem with noise coming from somewhere around the top of the boiler. It's a loud...
J
We’re thinking of replacing our veritable Ideal Mexico Floor Standing Boiler (installed by me in 1985 and pretty much reliable ever since!) with a...
W
My Worcester Combi Boiler is not working, instead the display flashes on and off repeatedly, as shown in <a href=" View...
Recently over the past 2 months, the boiler or area by the water tank has started making a loud groaning noise whenever hot water has been running...
2K
    • Agree
Hi all, We've bought a property that has a Worcester Greenstar 37CDi boiler installed, with an old British Gas RS2 Thermostat linked to it. I'm...
15K
Philip B
