Discuss New kitchen tap and low water pressure in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
I recently installed a new kitchen tap which has slimmer flexi hoses to the previous tap. After installing it I noticed the water pressure has dropped everywhere in the house. If I turn the isolation valves for the kitchen tap off, the pressure returns to what it was previously. I don't understand how the tap affects everything else in the house. Would changing the flexi hoses to wider ones potentially fix this issue?
Reply to New kitchen tap and low water pressure in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Hi Anyone know of a pull out kitchen tap that has decent pressure? I have had low pressure from this tap for a number of years and it's not...
My outside tap has had really low pressure after the cold weather a few weeks ago. Its connected from under the kitchen sink, and can be isolated...
Our kitchen mixer tap has started dripping. Like so much of the plumbing in our almost new build bungalow, it is lacking! The plumber didn't...
Plumber had fitted a new mono kitchen tap. The hot water takes ages to get hot if at all. The on lever hadn’t much turn on it and it’s at full...
