Discuss New Header going in in the Plumbing Jobs | The Job-board area at PlumbersForums.net
MarkAqua
As above, nothing too exciting. That's next week - New steam boiler to install :angry_smile:
Sorry about the direction? It's the right way up on my computer but when I upload it becomes the wrong way?
What's the preferred thread sealant these days for larger stuff?
Can't see and hemp and pase, or has it been cleaned off?
Use Loctite '55 generally - some specs still ask for Hemp but not done it for a long time.
Wow! And that's good enough for 2" mild steel.
I've not tried it yet, but do you have any problems with it? Apart from being expensive!
Yep fine up to 2" never ever had a leak due to the loctite! It really is fantastic stuff! I weld anything over 2".
Reply to New Header going in in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all I have a problem with my hot water header tank getting warm water into it from the bottom of the header tank (not the hooked...
I am looking to replace my existing Vaillant heat-only boiler with a new Vaillant ecotec plus 630 system boiler (30kW). I have a megaflo hot-water...
I have a vented hot-water cylinder that was installed when the house was built - 38 years ago! It has a header tank in the loft and the cylinder...
C
I've got a Greenstar 8000 going through a low loss header feeding 3 circuits, two trad rads and one UFH. Will it increase efficiency by instaling...
I recently read a post / comment whereby there was a recommendation that if you are away from your home more than 24 hours, then you should turn...
