Discuss New builds-dropping pipework in a party wall in the Plumbing Jobs | The Job-board area at PlumbersForums.net
stratplus
Anyone know of where to find accurate information for dropping pipework in a party wall? I was always led to believe you can't do it due to regs/noise but looking at other plumbers installs they seem to do what they like.
Don't know about the relevant regs to be honest, but aren't newbuild party walls solid and at least 9" thick?
If so, can't see a problem with chasing them in, or fitting behind dot and dabbed plaster board as long as they will be protected
We've always been told not to but you still get some who do it as its quicker and easier sometimes
Not allways solid, ive seen some with a thin piece of rockwool between the two houses.
What's the pipe? Plastic or copper?
Either, its the noise transferrence im referring to. Having to jump through hoops on some properties where they have designed the boiler/bathroom and cloakroom and rads on the party wall. Pipes will be in the timber frame behind plasterboard.
Nothing about pipework to be found although mentions deep sockets.
I'd ask the building inspector if I ever saw one on site. First fix is done and in come the boarders, rare that anything gets inspected these days.
Reply to New builds-dropping pipework in a party wall in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I...
Sonya K
