Discuss New build - rad to towel rail in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Scott_D
Subscribed
I have been asked to change a rad to a towel rail in a new build bathroom
As you can imagine it’s 10mm plastic out the wall
Has anyone got an image of 10mm plastic into a towel rail so that I can show the customer how it will look if I just swap as they have asked?
Do I have any options other that opening the wall and changing to copper?
Best I can find online.
Depends where the studs are could pull the plate off and have a look etc then put the 10mm back in the wall and drill 2 new holes so they go straight into the valves
Don't think there's a different way to pipe it without damaging the wall. A better option would be a towel rail similar to this one that will help conceal the pipes better.
1200x450mm Anthracite Flat Panel Ladder Towel Radiator | soak.com
And use these in the straight rad valves to keep the pipes as tight to the rail as possible so they're barely visible.
https://www.NoLinkingToThis/p/drayton-push-fit-elbow-adaptor-for-trvs-lockshields-15-x-10mm/9970r
Is that the general standard of piping in the UK.?
If it is, it's absolutely woeful
But then again - have a look at the silicon finish on the edge of the shower screen to the wall.
Reply to New build - rad to towel rail in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi guys....we have an old Astracast sink top....I think its a composite sink....has a big single bowl. My wife thinks it looks scruffy....looks ok to me.....sound but the bowl has seen a lot of work. So she wants a new one...Astracast it seems are no more. The problem is its size.....looked...
