Discuss New boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
H
hassom
Hi, ok i am going to go for a Vaillant ecotec plus 837, had a plumber out today to quote me for the job. He recommended not to get Vaillant as the parts are plastic and break after a while he recommended me to get a "Intergas Combi Compact" did not state what model number as he didnt knw. He said its a good boiler and only 6 parts are too it :/ what do u guys think about the Intergas Boiler? Also my boiler is right by the back door and the flue currently is around 4ft from the boiler, He said to get a virtical flue as its cheaper... but then he said sometimes a horizontol flue is good.... anyway wht boiler shall i get the intergas or vailant? horizontol or vertical flue?
id stick to vailliant also boiler /flue has to be 300mm from an openable door or window
Vailiant are a reliable boilers & have an excellent track record, Intergas are fairly new, sound good, but time will tell !
vailant are slowly turning into gloworms lots of poor quality plastic in the new ones id go for a remeha built like vailants used to be
used to fit nothing but vailant until recently had problem with new boiler and tried to phone technical support and got redirected to £1.50 per minute phone no.Principals now kicking in and looking to use another manufacturer. Remeha sound good.
veissmann, 5yr garentee,vaillant are good boilers and still fit a lot,but for me 5yrs compared to 2 yrs sells it
i would not touch a Vaillant , remeha are very good ,intergas are the way forward tried and tested with no fault designs like every other combi, they always condense it hot water mode which other boilers dont do
intergas will also give you hot water if the pump fails, no other combi will.
download the brochure here
[DLMURL]http://www.intergasheating.co.uk/lijsten/files/092206%20-%20Combi%20Compact%20HRE%20brochure3.pdf[/DLMURL]
valliant had probl;ems with the pumps on them for 2 yrs they sorted it each to there own but add stick to vailliant or baxi/potterton
Reply to New boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
