- Messages
- 10
Discuss New boiler - questionable install in the Gas Engineers Forum area at PlumbersForums.net
I think it’s acceptable as it’s no different from a brick, et al. The flue must be 300mm away from an opening to the building, other regs do apply but not in this scenario.I'd suggest even if it's been sealed up, it's too close. Not sure the gas regs would consider anything other than the possibility that the vent could pass air, so long as it it is there at all. (Waiting to get shot down by the forum gas installers if this assumption is wrong).
If sealed with mortar, I'd agree. But what if a DIYer had bunged silicone in it in the past to stop the draught? Surely still a vent? We had a recent discussion about what if a window pane is replaced with a bit of hardyboard and I thought we concluded it was still a window that could easily be turned back into a window. Hence my train of thought. Not saying I'm sure, mind you.I think it’s acceptable as it’s no different from a brick, et al. The flue must be 300mm away from an opening to the building, other regs do apply but not in this scenario.
Quote stupilates installing supply for fused spur.True. Worth checking the quote. It may say 'connect to existing electrical installation'. But logically the extension lead plugs in somewhere.
OP - how is the extension lead plugged in?
The pipework routed outside looks to be an overpressure or condensate pipe and is probably correct to go outside (you can always post up a photo for us).
They removed the toilet without it being agreed?!
Just another question. If this was sealed up, would I need a vent in the bathroom with it having a boiler in?I'd be happy if it was well sealed with mortar (no loose bits). I'd also seal internally but probably wouldn't pull it up on service if it wasn't.
No, these boilers don’t need ventilation for cooling and take their combustion air from outside via the flue.Just another question. If this was sealed up, would I need a vent in the bathroom with it having a boiler in?
Thank youNo, these boilers don’t need ventilation for cooling and take their combustion air from outside via the flue.
Is the installer gas safe registered? I would be contacting gas safe in that instance anyway, especially as he has no intention of fixing a trivial issues.Thank you
And have a picture from the outside now. Definitely not filled in
Yes registered with gas safeIs the installer gas safe registered? I would be contacting gas safe in that instance anyway, especially as he has no intention of fixing a trivial issues.
Reply to New boiler - questionable install in the Gas Engineers Forum area at PlumbersForums.net
