Discuss NeoAir RF not turning off heating? in the Central Heating Forum area at PlumbersForums.net
All.
I hope you can help. I have an Intergas HRE 30 SB boiler (plus tank) which is driving a combination of (downstairs) UFH plus (upstairs) rads, all controlled using a combination of Heatmiser NeoStats (UFH) and NeoAir w/ RF switch (rads).
On the surface, the Heatmiser App suggests there are no problems. However, by example, the house is currently supposedly on Standby (Holiday mode) and yet the heating is quite evidently still ON. It’s causing particular problems not just because of the worry of BIG bills (to come) but also I’m having to turn off the bedroom rads just to get some sleep. The timer seems to work fine for downstairs but not those connected to the RF.
It all worked fine when originally installed but then spontaneously started this behaviour about a year ago. I keep thinking I’ve “fixed” it and then it reccurs.
What could be the problem here? I’ve added the NeoAir back as a new Stat a couple of times to see if that resolves things, but no joy. I’m presuming it’s linked to the failsafe but how can I diagnose this?
Many thanks, Steve.
I have. A few times. Just recently in fact. Then I reset it for good measure (to try to sort things, and in doing so, worked out what “mode 3” was for! (when I had no water!))
Hi Steve
I have exactly the same issue. Its driving me crazy.
All hours the heating comes on and I'm up at 2am turning off rads then getting up before 6am to get them ready to turn back on.
Tried resetting the system, boiler off, unplugged everything.
It seems to fix it for a day or two then revert to doing whatever it wants. UFH seems to be working okay though.
Did you get any further information?
Thanks Linda
Hi Steve
Thanks Linda
Hi Linda.
Sorry for late reply. I did get it working. Essentially I moved it. I think it was a comms problem. If it doesn’t have a good signal then it defaults to on (for “safety”) and I think it was doing this. I moved it out to our landing which is directly above the RF switch and it’s been much better since.
Have you tried doing this?
Thanks, Steve.
Reply to NeoAir RF not turning off heating? in the Central Heating Forum area at PlumbersForums.net
Boiler is a Viessmann 100-w (2021 version) heatmiser uh8-rf heatmiser rf switch (intended for boiler enable only) Heatmiser neoair thermostats I...
8K
I have a Heatmiser UH8-RF controlling my underfloor heating, connected to the NeoHub with three zones with NeoStat v1 thermostats. This is about...
2K
Hi, I'm after some advice on converting my current CH system to Wiser smart system. In particular, looking for advice on whether I can use the...
Hi all, We had a new combo boiler (Intergas eco RF) installed about six months ago. When we are using the central heating and then use hot water...
Deleted member 120897
Hi folks, I’m in need of some sound advice. We have recently had a ground floor extension and have had underfloor heating (company: JK UFH)...
4K
