Discuss Need help with unidentified part of toilet tank in the USA area at PlumbersForums.net
Any idea where this piece that i'm holding goes? And will it help to stop the issue i'm having of water leaking from the tank into the bowl?
Am I correct in thinking that you`ve recently had somebody in to fix this, paid them but still have the same problem. If so then I`ll say it was replaced with the smaller and different valve in the top right of the photo so you can throw it away.
1) Looks like old valve bit: chuck it. 2) How quickly does the water leak? The square bit acts as an overflow so might be a case of just adjusting the float on the new valve to lower the water level. I always find flap valves let a little dribble past but nothing to worry about.
Reply to Need help with unidentified part of toilet tank in the USA area at PlumbersForums.net
Hi All I have a leak coming from within my Mira Elite QT shower. It seems to be flowing from behind the switching Control. Any ideas what could...
