Discuss Need help identifying the item and its issue... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have this shower fitted in my en suite. It's stopped working/responding entirely.
It was working then mid-shower it stopped and both buttons now flash slowly and don't respond to being pressed or held in any combination I've tried.
I'm after some help identifying the part so I can find out if I can fix/replace it or if I need to get a professional in to sort it.
Thanks in advance!
Have you tried looking at the instructions under fault as it should tell you what’s the flashing for ?
Aqualisa Quartz shower. That part is just the control - it has a pcb directly behind the buttons. Very easy to replace that entire control - just a single screw on base and a plug in cable.
But the Processor (main part of shower, remotely installed usually in attic or a cupboard) might be faulty and is expensive.
There are different models for combi boiler or gravity fed systems.
Reply to Need help identifying the item and its issue... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
