Discuss neagtive head shower pumps in the Plumbing Jobs | The Job-board area at PlumbersForums.net
mfgs
Does anyone know which negative head shower pump can be fitted almost level with the base of the cold water storage tank? I am looking to try and fit one but I don't have much space. I think Stuart turner pumps normally ask for it to be about 500mm below the bottom of the tank?
Your right most manufacturers ask for around 500/600mm but I think you can fit them next to a tank if you fit it with, water starvation protection.
I have seen them fitted that way and they work. I just don't want to fit one and void the warranty on an expensive pump.
Reply to neagtive head shower pumps in the Plumbing Jobs | The Job-board area at PlumbersForums.net
The left rear floor corner is highest (the shower pan touches/sits on the floor), sloping down diagonally to the front right corner (lowest). The front right corner shim is 5/8", the left front corner is 3/8" shimmed, with shorter shims under left middle and right rear corner. The pan perimeters...
