Discuss Myson Midas Boiler fiiring up when running cold water in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
_Chris
Hello
My Myson Midas combi boiler (25 yrs + ) has developed an irritating problem. All is working normally except that it fires up when a cold tap is turned on even a little and when the toilet is flushed.
It fires up periodically to top up the water temperature in the hot water reservoir during normal operation which is a bit of a waste really so we normally leave the hot water switched off at the boiler & only switch it on when hot water is needed. Yesterday, I forgot to switch it off after use and it was then that I noticed the problem.
I'm OK working on this boiler and over the years I've replaced the fan, main circuit board and pressure relief valve.
Could this be a problem with the hot water flow sensor or is it something else?
Cheers
Chris
You're not "ok working on this boiler" unless you are registered and qualified to do so. Please read the forum rules.
Reply to Myson Midas Boiler fiiring up when running cold water in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have a 2 pump hot water tank (Flomax 180L fitted in '94) in airing cupboard system with an Ideal classic boiler (downstairs next to an external...
Hi all, I have a wallstar combi oil fired boiler. We got low on oil a couple of weeks ago but didn't run out. Since we've had our oil delivered...
T
Please advise me. I am a disabled pensioner. I had a wet room fitted just over a year ago using a local authority grant. Builder was employed by...
TheCatWhoNeedsaHotShower
T
Hi, I have a Vailant EcoTec Boiler with a Megaflo. These are controlled by a Honeywell controller. I have one 3 port diverter, where one of the...
