Discuss Myson actuators fit wundafloor manifolds in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
Cubbs
Hi
does anyone know if the two makes are interchangeable?
im keen to go with mysons stats etc but need to know whether I have to use their actuators for ufh manifold
thanks
You don't need to use myson actuators with myson stats...
A Stat is a stat, an actuator is an actuator. We tend to install Heatmiser Neo for room by room control with the heatmiser wiring centre and emetti actuators, manifolds and pipework.
Myson do a 24V and 230V actuator, the Wundafloor actuator is 230V, so you'll need a wiring centre that controls a 230V actuator. Myson do a wiring centre for both 24V and 230V, the wireless wiring centre is 230V only.
Beware Wireless Stats, unless they use a mesh network you can have BIG problems with communications to the wiring centre. Hence our preference for Heatmiser Neo.
Reply to Myson actuators fit wundafloor manifolds in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Does anyone know a good, not super expensive, leak detection company in the London area?
