Discuss Motorised valve clicking in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
Just discovered a loud ticking noise coming from the boiler area and the zone valve seems to be causing it with a metal lever moving in one direction then resetting and trying again.
It's only just started and system is new, less than 6m full CH replaced, pipes/rads/boiler/magnetic filter etc.
Is there anything I can do as a competent DIYer before I get hold of my plumber on Tuesday?
Reply to Motorised valve clicking in the UK Plumbing Forum | Plumbing Advice area at PlumbersForums.net
New install, under a year old. Boiler downstairs. Mega flow upstairs in airing cupboard. Undfloor downstairs. Rads upstairs. Whenever the...
 Our heating stopped working today. We've got a Veissmann boiler that's under a year old, and an older Megaflow cylinder, and two diverter...
I'm in a bit of a bind with a current CH install where I need to install a filter prior to a flush but no where to install My issue is the...
So, I went to this job yesterday to change over a faulty motorised valve on the hot water side of an unvented system. I drained the system, wired...
Hello, my Mothers heating failed in the recent UK cold snap. I found the pump was stuck. I have a question about pump orientation. The...
