Discuss microbore valve connection in the DIY Plumbing Forum area at PlumbersForums.net
Hi all, just removed a radiator while decorating. One side was easy, the other just spun round and is now leaking. Have drained down system but not sure how to fix leak (not seen this connector before) ps was really tight - split the olive? The whole connector is spinning round.
Thanks in advance.
So it measures 8mm od just above the paint ?
Was the valve a trv ?
Yes snap reducer
You need to remove all the water from the pipe before soldering
You will need an 8mm coupling, short bit of 8mm pipe and either a 3 part reducer 8-15mm or a soldered 8-15mm reducer and a 15mm olive
Thanks Shaun. Mrs said I should have left it and just papered behind but like to do things properly and when I took the rad brackets of only 2 screws were doing anything so going to sort that.
Appreciate your quick replies.
Reply to microbore valve connection in the DIY Plumbing Forum area at PlumbersForums.net
Hi there. I’ve installed a new towel radiator and I’m trying to fit the valves but I’ve come unstuck and need some help. I’ve bought new angled...
Hello I want to replace the old single panel rad in the bedroom with a K2 double panel Stelrad one. I think I'm OK in general and relatively...
Hi, Short version: I have about 4" of pipe sticking out of a concrete floor in a cupboard. It makes a 45-degree bend as it exists (bent, not with...
Hi, We moved into a house a couple of years ago and inherited some "interesting" plumbing throughout. Today's problem is that the bathroom towel...
2K
  • Solved
Hi There, I want to swap out my old valves for TRVs but the threads are different sizes, and I'm unsure how to resolve it. My current existing...
2K
Daley power
