Discuss mico bore heating pipes clipes to breeze block before dot and dab plasterboard in the Plumbing Jobs | The Job-board area at PlumbersForums.net
is duct tape ok for corrosion protection on micro bore central heating pipes clipped to breeze block walls before dot and dab plasterboard
No............ but for some reason people do it and wonder why it can leak later on due to corrosion
its no but dont forget about expansion and contraction will need a bit of space
Will not rot, but will creak amd groan when expanding. 10mm plastic coated all the way.
Reply to mico bore heating pipes clipes to breeze block before dot and dab plasterboard in the Plumbing Jobs | The Job-board area at PlumbersForums.net
