- Messages
- 710
This might be a Stupid question so I do apologise.
if I have my boiler on programme setting and the heating to come on at 2pm ATM the moment it is 1pm and the room temperature is 12 degrees so If I go over and turn the stat to 20 degrees the boiler will fire up until the room temperature has reached 20 degrees and then will switch off? I understand this part.
This is the problem i don't understand because the room stat is on 20 degrees from the last time I turn the dial.if the timer on the boiler wasn't to come on yet, until say 5pm but the room was about 12 degrees do I need to turn the room stat all the way back to 10 degrees too then 20 degree until I hear the click?
I'm a wee bit confused ?
