Discuss Maybe a silly question - replacing a power shower in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello
My Gainsborough PS1200 has given up the ghost so i'm on the look out for a replacement.
This may be a silly question but Do I need to call a plumber, a sparky or ..... both?
Cheers
Depends what's there mate. Some plumbers will do the lot it hinges on what's I place wires wise and switch wise. Most plumbers will know what's required but may have to enlist a sparky if cable upgrading is required
if its like for like, a plumber should do it easy
Reply to Maybe a silly question - replacing a power shower in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, this is probably a daft question but I need to run my cold feed from one side of my wall mounted boiler to the other. Running it beneath the boiler is difficult with lots of obstacles, is it okay if I run soldered copper over / across the top of the boiler? It'll be about 4" off the top...
Hi All, I am looking to take my bath out and fit a shower. Regards to tanking. Is it ok to just seal everything with plastic rather than just paint tanking slurry? Thanks in anticipation, best regards Staggers
