Discuss main combi eco fault in the Plumbing Jobs | The Job-board area at PlumbersForums.net
F
fixter1
freind of mine rang me today to go have a look at his boiler, he said that when he has his heating on the lights for heating and hot water are switching from one to the other all the time could it be the diverter head at fault im going to have a look at it in the morning thanks
Could there be a hot tap slightly dripping, dhw ntc detects temp change & fires for dhw then returns to heating, then repeats ?
A phone call might answer this.
thanks mate ill give him a ring the problem is the shop he has the boiler all so supplys the flat down stairs lol , correct me if im wrong but wouldnt the hall senor activate
If you're referring to the roomstat [hall sensor] on a combi it's hot water priority.
If it's the Hall sensor on the fan, that only detects that the fan is spinning.
hall effect sensors are fitted to a magnetic read switch its basically a flow switch the light would be on if a tap was dripping if there was a leak ,the sensor could be at fault to test pull the hall effect sensor off stick a magnet in it and open a hot tap if it runs ok put it back on the read switch and repeat test, it could well be a sticking motorized/diverter valve these can be cleaned up and silicone grease applied to the gubbins
would there be water where the head fits on the diverter never done one on this boiler
yes around the pin and bush,take the motor out(easy) and shake it to your ear if its full of water theres your fault,now i dont think baxi do a refurb kit a ariston bush may fit but i have never tried and you need a new motor
sticking motorized/diverter valve these can be cleaned up and silicone grease applied to the gubbins what are the gubbins???? sorry if i sound daft but new to repairs
the bush and spindle but you need to remove it from the diverter
do you need to remove the hole diverter or can you remove it in place the shop was closed today so im there monday morning
no diverter stays in,drain down undo the bush it all comes out from the top
its the bush circled but obviously the other way up in the boiler;)its under the black or black and white motor depending on age,pull out the retaining clip drain system undo the brass bush pull that out with the springs attached,clean them,put silicone grease on the silver rods and on the bush o ring
also put magnet on hall sensor the hot water is ok put it back on no hot water
you have a domestic hot water switch down if it works by putting a magnet on but not when back in situ in regards to the bush if theres water on the pin there may be water in the motor this would cause the boiler to either blow a fast fuse or go to dhw/htg at the same time or jump constantly between both
like i said if i put a magnet on it works fine, if i put it back on i have to run the tap full belt for the light to come on and the waters cold so i need a new hall sensor is that right???? gasman
yes new hall sensor needed but not the clear plastic part the brass section
405 H33273HYDRAULIC INLET ASSY WITH HALL EFFECT SENSOR - 10 L - 24 HE5116017
part number
[DLMURL="http://www.gas-spares.co.uk/Catalogue/POTTERTON-MYSON/BOILERS-COMBI/GOLD-Range/GOLD-24-HE-A/HYDRAULIC-INLET-ASSY
t"]GOLD 24 HE A - Gas Appliance Spares (Preston) Ltd[/DLMURL]hey are showing the complete thing but if you ring baxi tech on 08443358428 they should be able to give you the pn for just the switch
Reply to main combi eco fault in the Plumbing Jobs | The Job-board area at PlumbersForums.net
