Discuss Main combi compact 25 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Atanas Peev
Hello anyone know why the combi main compact the new model show 000 and fail ignite from first commissioning
Thank you
Did you go through the de airation ?
But now I’ve got another problem with Worcester Greenstar 24 the boiler start and stop during the open tap or call for heat investigation TIL now is just rise the CO concentration in the flue system
Any experience with this
Thank you
Thank you
You have ignored the question of are you Gas safe registered?
I’m guessing your not. As when I type your postcode in to the gas safe website your company doesn’t come up. Please stop working on gas appliances if you’re not qualified to work on them.
Thread closed until GS details received
Reply to Main combi compact 25 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I have just looked back through the regs this seems to have changed and it isn't mentioned now. It now mentions if at high level it should be discharged...
  • Sticky
