Discuss Magnetic filters, Again!! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
J
jase158
I am confused by spyrotech filters, is it possible to remove the magnet? if you open it will the water automatically turn off or go all over the floor? seen 2 in last week and wasnt sure of any way to remove magnet so just opened up and flushed out the magnet. cant imagine this is too good though.
Thats all I do to them, I have never even thought about removing the insides, its all mesh stuff inside there anyway.
The MI's just say to drain through the valve at the base.
The bowl is easily removed, but then if no valves are fitted (they don't come with valves) it means draining the system.
the cap you screw of the outlet doubles as the valve handle just squirt it in to a bucket
Reply to Magnetic filters, Again!! in the Plumbing Jobs | The Job-board area at PlumbersForums.net
A bit of history first. 2 yrs ago visited a grant boiler with boiler and pipework kettling. I added SentX200 noise reducer. It is standard open...
Hello, my Mothers heating failed in the recent UK cold snap. I found the pump was stuck. I have a question about pump orientation. The...
Hi, I need to drain my vokera 29 boiler in the attic as Im going away for 4 weeks at least to make sure there are no frozen pipes. In my small...
We live in a 1980s four-bedroom detached house. The time has come for new central heating. The current system is a mild revision of the original...
2K
Good Afternoon all, I am hopeful someone may be able to offer some guidance on the following. In the home we have a gas boiler (serviced...
