simonB_2010
I'm was looking for a MANUAL changeover unit for 2 propane cylinders, I need a working pressure of 1.5 or better, 2 bar.
The reason I want a manual rather than auto, is to do with the end application.
I'm firing a pottery kiln, and as such the gas requirements start very low, building up over 6-12 hours, when at the top temperatures it usually requires all the gas you can feed it.
I really want the ability to switch to a new full cyinder exactly when I need it.
However, I found that maunal c/o's only seem to be available at low pressure (37mbar).
Once you go past 37mbar, the only c/o's I can find are automatics.
So questions :
> Anyone know WHY changeovers are not available as manual at High Pressures ?
> Any suggested alternative solutions to my problem ?
Many Thanks
Simon
So questions :
Many Thanks
Simon
