Discuss Low head pressure tmv suitable for unbalance supplies. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Sharp Point
Got a 'doc m' pack to fit soon in a working mens club, the hot is being supplied via a wall hung water heater, the type being fed by a little cistern above, the height of the water level is approx 2m above floor level and the tmv for the new wash basin will be approx 1.5m below water level. and to add another spanner in the works, the cold is off cold mains. Is there a tmv on the market that will work with this set up.
cheers
no the only way is prv down to same out pressure as r25
Even with prv it probably won't work you have 0.15 bar hot water don't think you can get cold through prv down enough, I have just taken out exactly the same set up from community centre because all they ever got was cold water.
they do work thats all one comp have been doing round here, the only other option is use of an ariston mains water heater
I'm taking a brand new one of these out next week! Your welcome to it mate!
A spark wired it in with a 3 pin plug about 300mm away and below the basin!!
Thanks for the replies, I knew it'd be touch and go as to whether a low head/ unbalanced tmv would be possible. I have notified the builder, that'd he's probably going to have to get an unvented set up.
Reply to Low head pressure tmv suitable for unbalance supplies. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello - am hoping someone out there can offer some advice... I've been living in a split level 1st & 2nd floor masionette for two months, which...
4K
I’ve had a local church ask me to lower the cistern as it has no cold feed and no water on site to get it there. The boiler is a Powrmatic Sime...
Hello, I have a had a gravity boiler replaced from a Potterton 80e to a more recent Valliant ecoplus boiler. The cold water tank is in the loft...
2K
Situation: Had a boiler system conversion. From Potterton boiler with Gledhill storage tank with on demand hot water to Veissman Combo with on...
2K
Hello, Trust everyone is well and keeping safe. Apologies in advance for the lengthy post but I could really do with some advice as I'm mid...
2K
