Discuss Looking for work plumbing/plumbers mate..Essex/Suffolk based in the Plumbing Jobs | The Job-board area at PlumbersForums.net
If you have done pipe runs and fitted baths etc why dont you try advertising for basic work....i.e. changing taps, fitting sinks or toilets etc. You say you have some knowledge the only way you can really learn is to get stuck in and have a go. Il say this it wont come to you you need to get out there and do it. Good Luck
I appreciate that mate,i was thinking of that..If you have done pipe runs and fitted baths etc why dont you try advertising for basic work....i.e. changing taps, fitting sinks or toilets etc. You say you have some knowledge the only way you can really learn is to get stuck in and have a go. Il say this it wont come to you you need to get out there and do it. Good Luck
If your still looking for work. We have site work in Essex and Suffolk area.
Please call Sandamoss on 01621 854804.
I have yes,couldn't promise me work..also worked only in copper and not plastic,so would need to learn..
i have yes,couldn't promise me work..also i have only worked mainly in copper and not plastic,so would need to learn..
I have yes,couldn't promise me work..also i have only worked mainly in copper and not plastic,so would need to learn..
I wouldnt mind some experience in plastic..if your ok with copper you will be a pro at plastic, its the easiest method of plumbing push fit instead of solder blah blah blah
i hate plastic but its the easiest
LOL :yinyang:Kisses? That an't going to get u no where mate...
Reply to Looking for work plumbing/plumbers mate..Essex/Suffolk based in the Plumbing Jobs | The Job-board area at PlumbersForums.net
