Discuss Looking for a guy with a commercial ticket in the Plumbing Jobs | The Job-board area at PlumbersForums.net
mutley racers
Subscribed
In the London area to install a 65 kw boiler in replacement of a 35 kw boiler and cut into 1 1-2 inch iron pipe and put test point and 28mm valve for me to walk in small boiler.
I live in Essex and can be in London in 1.5 hrs and have non domestic gas safe registration]
Can come have a look for you ?
When would be a good time for you to pop around? I have been told that the boiler is actually a 65 kw domestic. So just need the pipe being tee'd into. As I said, what ever it costs
So you are interested in some work? I have 2 churches that I need to install a couple of boilers in. One in ealing and one in Harrow. The one in ealing I believe needs a bigger gas pipe put in. It has 2 inch barrel but I don't believe it's big enough. And a test point cut in with isolation so I can install 2 logic system boilers
If there is an ISo. Use inlet on gas valve of boiler as your test point.
Reply to Looking for a guy with a commercial ticket in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, My current hot water system needs to be replaced. Anyone got any suggestions or can recommend any plumbers around Derrimut area that won't...
