Discuss Lip inline hot water heaters in the Plumbing Jobs | The Job-board area at PlumbersForums.net
L
Lag1rich
Any ideas what is sent if I oreder piping kit ZL001? for a Zip inline ILX009?
Thanks, Richard
Reply to Lip inline hot water heaters in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I have a Worcester 28i junior boiler that has started to lose pressure, only when using the central heating. When using hot water I have no issue, however, when running the heating the pressure drops. Im looking for some ideas on what could be causing this. I have no sign of pipe leaks...
