Discuss Leaky trap underneath kitchen sink in the USA area at PlumbersForums.net
My kitchen sink trap/waste is leaky a bit from the connection highlighted below. It mainly happens when there is pressure (when I fill up the sink and open it in one go), and the connection becomes a bit loose and water starts pouring out. I have tried tightening cap, but after a while it drops down (especially when there is a lot of water coming from sink, it just pushes it down. Would I be able to just replace the two traps (I am really sure what it is called) coming from sink drain to this T shaped trap? Or do I need to replace the whole thing? What should I be searching for in screwfix/wickes? Thanks for the help!
Ooh, I hate those types of arrangements. Yes recommend getting rid of the lot and using a McAlpine set of traps, or a kit. That washing machine hose is asking for trouble as well.
Perhaps it's an earlier version of one of these:
Might be easier to replace the whole thing than work out which McAlpine bits you need!
Also available from John Lewis! Franke Siphon 2 Sink Plumbing Kit - https://www.johnlewis.com/franke-siphon-2-sink-plumbing-kit/p3240553
It also needs clipping to the wall to stop it slipping down!
1. Push it back up into position.
2. Tighten the connections to right and left. Even better, dismantle, clean then reassemble and tighten.
3. Screw wooden block(s) to the wall tight up against the underside of the horizontal pipework. Should stop the pipework dropping under load.
Reply to Leaky trap underneath kitchen sink in the USA area at PlumbersForums.net
    • Useful
My parents have a leak from kitchen sink. My dad removed waste trap and since refitted it leaks, but there wasn’t any kind of seal on it, I got a...
Hi all, I'm installing a concrete patio out back. By the wall under the kitchen sink I have an existing P-Trap gully for the grey water from the...
Sonya K
Hi all I really need some help or advise….. Back story….. Some years ago my dad had an extension to his house which included a newly built...
Hi, I have noticed the hot water faucet under the kitchen sink is leaking. It seems to be leaking underneath the cupboard. The flexible...
