Discuss Leaky kitchen tap - what is this replacement part called? in the USA area at PlumbersForums.net
Hi, my kitchen tap has been dripping.
What is this replacement part, below images?
Its a cartridge, either ceramic disk or full turn type, beware they are not all the same , take it to a merchants and try and match it .
Reply to Leaky kitchen tap - what is this replacement part called? in the USA area at PlumbersForums.net
Hi there I have attached a video below, showing where my kitchen tap is leaking from, is this possible to repair by replacing the hose pipe or...
I have a kitchen mixer tap with quarter turn levers and the cold side started dripping. I took out the ceramic valve and replaced it with one from...
Hi, I need to replace the O rings on the spout of my kitchen tap. What lubricant do I need to use in order to aid fitting the new O rings...
I have a Bristan Manhattan mixer tap in the kitchen. Five years ago, it started to drip. I replaced the valve in the cold water side and the...
Hi, My Blanco Kitchen Tap Model Swift BM1420 is leaking. Please see attached photos for details of where water leaks from. What I've done so...
