Discuss Leaking side entry flush valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi. Looking for some hopefully very simply advice. I needed to replace a side entry flush valve on an enclosed toilet. I have installed the new flush valve but am having problems connecting it to the mains water supply pipe. The flush valve is 1/2" and pipe is threaded plastic. The mains supply has a corner fitting with a push valve, I think its 15mm. I am guessing I need some form of connector which will fit the mains push valve and also connect to the threaded flush valve pipe - but I just dont know what I actually need. Any help/advice would be really appreciated, thanks
A piccy might help. But do check the plastic connection as its dead easy to cross thread the join. centralheatking
Thanks, will take a pic tonight. The gap between the flush valve threaded pipe (I think its called a shank?) and the push valve from the mains is too large to connect the two directly.
The previous flush valve had a much shorter pipe/shank and there was a connector in place between the two, but cannot be re-used as it was stuck and I had to cut through the old flush valve to remove it.
I went to DIY store and got a tap extender which I thought looked very similar to the previous piece, but it leaked everywhere when I switched the water back on. Not sure if tap extender was correct? There wasnt any olive or washer etc included.
Hi. Pics attached. Thanks
remove the push fit
Install a compression elbow
Then install a straight tap connector with a piece of copper between to match your setup
Reply to Leaking side entry flush valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello I am looking to install a slimline dishwasher (integrated) into a cupboard in my kitchen. The depth of the dishwasher is 550mm and the depth of my cupboard is larger than this. The issue, however, is that the waste pipe which leads from the sink (next door cupboard) comes out quite a...
