DutchNibbles
Hi All,
Sorry for the long post...
I'm looking for some advice on my leaking radiators and boiler. I have recently had to replace three radiators due to them leaking from the bottom edge. I now have two others leaking, and the paint on one has bubbled up quite dramatically!
I have been advised that the boiler has created some kind of corrosive (the waters not mixing properly?!?!?) and i can expect more radiators to fall under the same fate if the boiler is not replaced. The piping is also causing a problem...
The piping is using a NON BARRIER PE pipe, which has been found to allow oxygen to be drawn across its surface and into the water within and this is bad news for a heating system.
If someone can supply any advice, it would be greatly appreciated. Beware! i know nothing about plumbing and i'm just quoting advice and information i have been given!
Thank you
Thank you
