Discuss Leak under kitchen sink in the USA area at PlumbersForums.net
Good afternoon. I have an intermittent leak on a “valve”(?) just above the cold water stopcock under the kitchen sink. It appears to be only leaking for a short period after using the kitchen sink. Can anyone advise what this valve is and is it easy to replace. This has obviously been going on for some time and was concealed by a waste pipe leak under the sink which I have now rectified. Thanks in advance.
Good afternoon. I have an intermittent leak on a “valve”(?) just above the cold water stopcock under the kitchen sink. It appears to be only leaking for a short period after using the kitchen sink. Can anyone advise what this valve is and is it easy to replace. This has obviously been going on for some time and was concealed by a waste pipe leak under the sink which I have now rectified. Thanks in advance.View attachment 47270
Hello
this can only be leak when you use your kitchen sink? maybe or maybe not this valve does not leak
Reply to Leak under kitchen sink in the USA area at PlumbersForums.net
Hi all, I'm installing a concrete patio out back. By the wall under the kitchen sink I have an existing P-Trap gully for the grey water from the...
PSxxxxxx
