Discuss Leak Sealer and Boilers in the Plumbing Jobs | The Job-board area at PlumbersForums.net
plumber5
Reading the various posts it is apparent that leak sealer -
1. Works only if the hole is small enough
2. Tends to have a limited working life span
What is not clear is the affect it might have on boilers -
Being based in London with its hard water would it be right to assume that leak sealer might block up the heat exchanger on an older boiler?
Any advice would be welcome......
I believe leak-sealers aren't recommended on modern boilers by some manufacturers as they can block the small holes in the heat exchanger. Should be fine on older boilers but best to check with the manufacturer.
Are you certain the leak is in an inaccessible part of the pipework?
Waste of time IMHO. They clog everything up including trv's and AAV's
Reply to Leak Sealer and Boilers in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi. I'm having some issues with my boiler / central heating and have enlisted a local 'Combi Heating Specialist' to sort it out but he seems to be...
3K
We live in a 1980s four-bedroom detached house. The time has come for new central heating. The current system is a mild revision of the original...
2K
Hello, Can anybody please advise. For months now our old Ideal Mini HE C24 (combi boiler) has had pressure problems. It won't stay above 1 bar...
2K
Hi - I have a Myson Velaire oil boiler which was installed in 1988. The boiler has been very reliable only needing a good service and rarely a...
2K
Hi everyone - Recently bought a house which is currently heated via FHW via an oil-fired boiler. Hot water is also provided by the boiler (via a...
1K
